Just now, Mcv0126 said:
My cpu and gpu is not spinning when I turn it on
That alone doesnt mean PSU is at fault. What else have you tried? What PSU is this? What are the complete details of your system?
Gpu fans not spinning is quite normal as they tend to have a 0 rpm mode cpu not spinning is not normal however. Did you plug the fan header in of the cpu fan? Did you plug it in the right way?
A psu failure seems highly unlikely. Does the computer start up?
9 minutes ago, Mcv0126 said:
Hey, I just want to clarify if I'm correct. My cpu and gpu is not spinning when I turn it on but my chassis fans are spinning and lights up. My PSU is faulty, right? I already tried plugging my desktop to a different wall socket with the same results.
Your CPU and GPU not spinng means, you mounted them correctly 😄
If you are talking about the fans, you can unplug your CPU fan and make sure, you plug it in correctly.
Same thing for your graphics card's power supply cable.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
