Gigabyte B450M DS3H CPU cooler fitting? Will it work?
MistahHaskins
I had ordered the Cooler Masters Hyper 212 BE and I am using the b450M DS3H motherboard from Gigabyte.
Will this fit, and I hope they are compatible for AM4 sockets by now. Also I am using this case: https://www.amazon.com/Fractal-Design-ATX-Tower-FD-CA-Focus-BK-W/dp/B071G4KDKG/ref=sr_1_1?dchild=1&keywords=Fractal%2BFocus%2BG&qid=1624574715&s=electronics&sr=1-1&th=1
Case has a 165mm Limit and If I am not mistaken it does fit within the limits and that's why I bought it.
Gaming Rig:
CPU: Ryzen 5 5600x  | CPU Cooler: Cooler Master Hyper 212 BE  |  GPU: ZOTAC GeForce RTX 3060 Twin Edge OC  | RAM: Corsair Vengeance LPX 32GB DDR4 3200mhz  |  Motherboard: Gigabyte B450M DS3H V2  |  Storage:  WD Blue SN550 1TB NVMe M.2 SSD  |  Case:  Corsair 4000D Airflow  |  Power Supply: Corsair CX650w Bronze Series
Yeah, hyper 212s have always been compatible with am4 (atleast for the last 2-3 years) and the BE is a newer version which DOES support the MoBo you have.
As for the case, yes it will fit, case has a 165mm limit, the BE is 158, so you're good there too.
PLEASE TAG ME SO I CAN SEE YOUR REPLY!
CPU: AMD Ryzen 7 3700x  | Motherboard: Asus TUF X570 Plus | RAM: Crucial Ballistix 8gbx2 3600Mhz | GPU: Asus TUF RTX 3080 | PSU: NZXT C850 | Case: Corsair 5000D AF | Cooler: NZXT Kraken Z63 280mm | SSD: Samsung 970 EVO 500Gb m.2 ssd + Samsung 860 EVO 1tb ssd | Monitor: LG 49WL95C-W | Peripherals: Logitech G815 + Razer Viper Ultimate + Razer Kraken TE | Audio: Logitech G560
Case has a 165mm Limit and If I am not mistaken it does fit within the limits and that's why I bought it. I already posted this before and only got one response, just want to get more peoples opinions before it arrives tomorrow!
Gaming Rig:
