Hello,
right now I'm using a cheap "USB Sharing Switch" (click Link or see below) and now I'm looking for a better solution.
First of: Why am I using this:
I have both my work Laptop and my Gaming-PC attached to the same Monitor und want to use the same Mouse, Keyboard, Headset, Mic at both PCs. This works flawlessly with this cheap-o Switch.
What do I want:
The same but with Networking and in best case even video. I've got an "HP USB-C Dockingstation G5" for my Work-Laptop, but this only works with one device. Something like the G5 but with the option to connect to 2 PCs and switch between them would be perfect
Feel free to ask if I was not clear enough.
Thank you in advance
Windows 11 Pro 22H2
Ryzen 3600
Gigabyte B450M DS3H
GIGABYTE RTX 2080 GAMING OC
G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
https://linustechtips.com/topic/1367952-suggestions-for-replacement-usb-switch/
-> Moved to peripherals
What you're looking for is called a KVM switch. Will do USB and video, not network since you can just plug both?
F@H
GPD Win 2
