Loud System
Solved by DamDirtyApe,
No no just standard 3 pins... So If I get this Lian-Li will it do the job ??
It should be, but make sure you can still return it if it doesn't work out. I have zero experience with Corsairs' 3 pin fans so I'm not sure how they mesh with a fan controller. I've only used their 4 pin fans.
As for that fan controller, that's a really basic one for 19.99. If it matches your case very well, then awesome. Check out brands like Akasa, Scythe, BitFenix and NZXT. I've had a lot of luck with NZXT and have heard wonderful things about Akasa, Scythe and BitFenix. All the fans are basically going to do the same thing, some might just have a few more features, so pick one based on looks and, of course, reviews. That's what I would recommend though.
