I'll try to keep this short with relevant details.
Original build:
Z170 ATX mobo, a bunch of storage disks, one parity. All was fine apart from the case had bad airflow and I didn't like the temps.
Bought Node 804. Z170 was ATX so wouldn't fit. Swapped it with a mATX H81 mobo (Haswell). Added an extra controller card for more ports. Added two cache drives. System always missed some HDs on 1st boot, but they came back on a restart.
Swap the board with a mATX Z97. I just tried writing to it, but the controller card shows an IO error after a little use and I lose the cache drives. It was fine with the older mobo.
The controller in question is 6 SATA port, based on ASM1062+1093. That's PCIe 2.0. Since I'm only connecting HDs off it, I'm not concerned about the bandwidth. It worked fine for hundreds of GB on the H81 mobo but now the Z97 is giving me a problem. The only thing I can think of, which I'm about to try, is disabling spread spectrum, but I don't think there are many things to tinker with here.
Suppose worst case, I'll try a different controller as all I want are a bunch of dumb ports.
As far as I know the system is stable. I've even turned off XMP since it doesn't add value in this use case.
https://linustechtips.com/topic/1367489-unraid-woes-controller-disappering/
I had trouble with ASMedia controllers in FreeNAS, so I wouldn't be surprised if it's just bad *nix support. Getting a IT mode LBA would be your best bet (something like an LSI 9207-8i or such, just remember to get breakout cables too).
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
I'll keep that in mind as an option.
I've disabled spread spectrum and while I was in bios, also set MCE to disable. Both options were "Auto" which I hate, since I have no idea if they are on or off. Anyway, since applying those changes I have written 90GB without the previous problem reappearing.
On the down side, now I have 4 UDMA CRC errors on one of the drives hanging off that controller. Not as bad as before, but still not good. Again, this drive, with the same cables going to the same card, was fine with the previous mobo. Maybe I'll change the cable and see what happens. I'm half tempted to just ditch the cache disks for now, which are the only drives on that controller.
I've also had a bad cable cause CRC errors too, so yeah, try that first.
I've done a lot of on-again-off-again research regarding L2ARC in Free/TrueNAS (a form of caching), and I could never really justify it. Unless you're running huge database loads, the average user either doesn't access enough of the same data often enough to warrant more than RAM caching, or the array itself could already saturate any connections to it. Not sure how much different it is in Unraid, but I suspect it's pretty similar.
Network:
Very different. Unraid uses fixed parity disks, and to reduce load on inactive disks it will read-modify-write that parity data. This significantly reduces its write performance. Here, cache disks are used to get around that. They are primarily a write cache, since read performance is not affected by Unraid's system. I have two cache disks as a mirror for redundancy. Typical writes without cache may be only around 50MB/s, and with cache disks I can saturate gigabit ethernet easily. Using cache disks means I have to wait less for writes to happen, so they're not essential.
Ok, switched a pair of new SATA cables over for the two drives connected to the controller card. While only one was reporting errors, might as well do both to save me figuring out which one of the pair it was. Anyway, since then, no further errors have been indicated. I might finally be at the end of what was supposed to be a simple mobo swap. If a mobo swap ever was simple... hopefully now I can pretty much forget about touching it again until such point I get a disk that needs replacing, or I feel a need to add more.
