51 minutes ago, Nicholas Rodriguez said:
hey guys long story short i recently got a water cool loop kit for a ryzen 9 5900x and i have fans on both side of the radiator but as i kept checking my temps for my cpu, its roughly around 76 -80C is that still high for a water cool loop ?
Water cool loop isn’t specific anymore.  Is this custom loop or AIO?  Sounds like custom loop.
https://linustechtips.com/topic/1367363-water-cool-loop/#findComment-14948013
what size & thickness is your rad,
what voltage & clock speed is your 5900x running?
is pbo enable?
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
https://linustechtips.com/topic/1367363-water-cool-loop/#findComment-14948039
that's really high for cpu voltage, u might try undervolting it
for my case:
my cpu (ryzen 3600) stock it was running 4200mhz at 1.45 volts, i had same issue like yours 80-82c max
then i manage to find 1.2v is stable for 4200mhz (2 hour on prime95 small fft), now it's maxing out at 63c
https://linustechtips.com/topic/1367363-water-cool-loop/#findComment-14948609
