Temps rtx 3070
Solved by Kyle Xu,
59 minutes ago, RyanTaha said:i have an MSI RTX 3070 dual fan and i got it mainly for playing, and whenever my pc is idle iam mining ETH with it
So i have been wondering what temps that would shorten the life of my GPU
its temps go up to 58-65 C
would that shorten the life of it?
that's quite low for a 3070. Most modern GPU's are designed to withstand about 95c if needed. I would even say you could probably overclock it a bit
