I have recently put together a pc build and it will not post to bios or show any image towards the monitor.
Specs
I5-7600K
16GB of Team Force ram
970 Gigabyte
Z270 XPOWER GAMING TITANIUM
Kingston KC2500M8 M.2NVMe SSD 1TB
I cant see what the problem is and just need to know if there is something uncompatable
https://linustechtips.com/topic/1366327-help-wont-boot/
Specs
I5-7600K
970 Gigabyte
Is there any beeping when you power on?
If so here is the MSI beep codes to assist you.
https://forum-en.msi.com/faq/article/bios-beep-codes
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1366327-help-wont-boot/#findComment-14940205
Ive sorted it all out, I now have a gtx 1070 FTW from EVGA, but the new problem now is that games are not running smooth anymore getting only about 30 fps on low everything and in windowed 1920,1080
https://linustechtips.com/topic/1366327-help-wont-boot/#findComment-14943453
