I am trying to get started using Linux and have selected Pop OS. I installed steam and started downloading games and it worked for a week. Now whenever I try to download and install games from steam and sometimes just launching steam the entire system freezes and the only thing I can do is to press the restart button a hard shutdown.
Please help. I am new to Linux and have not been able to find a solution to this problem anywhere. I am not sure if my drivers need to be updated or how to do that.
PC Hardware.
  • CPU: Threadripper 1920X
  • Motherboard: ASRock X399 Phantom Gaming 6 ATX sTR4
  • Memory: G.Skill Aegis 64 GB (4 x 16 GB) DDR4-2666 CL19
  • Storage:
    • Windows:
      • TCSunBow X3 1 TB 2.5" Solid State Drive
      • Seagate Enterprise Capacity 10 TB 3.5" 7200RPM Internal Hard Drive
    • Linux:
      • Team MP33 2 TB M.2-2280 NVME Solid State Drive
  • Video Card: Asus Radeon RX 6700 XT 12 GB ROG STRIX
  • Power Supply: EVGA BQ 750 W 80+ Bronze Certified Semi-modular ATX Power Supply
https://linustechtips.com/topic/1366186-linux-freezing-when-using-steam/
PC Hardware.
  • Storage:
    • Windows:
    • Linux:
First you should update your drivers, To do this open a terminal and type these commands (make sure to write in lowercase as unix commands are case-sensitive)
sudo apt update
sudo apt upgrade
sudo apt autoremove
sudo reboot
And try again
Generally, yes.
7 minutes ago, WickedThunder86 said:
sudo apt update
sudo apt upgrade
sudo apt autoremove
sudo reboot
Yea, This should work. However, if you aren't comfortable with using the command line, I think you can update software using the store, but I'm not very sure on that
"The most important step a man can take. It’s not the first one, is it?
It’s the next one. Always the next step, Dalinar."
–Chapter 118, Oathbringer, Stormlight Archive #3 by Brandon Sanderson
Older stuff:
"A high ideal missed by a little, is far better than low ideal that is achievable, yet far less effective"
If you think I'm wrong, correct me. If I've offended you in some way tell me what it is and how I can correct it. I want to learn, and along the way one can make mistakes; Being wrong helps you learn what's right.
sudo apt update
sudo apt upgrade
sudo apt autoremove
sudo reboot
And try again
Thanks I will try that.
Not sure if it will help, but one thing I typically try when troubleshooting things in Linux is launching them from the terminal. Sometimes when things go wrong or crash you'll see messages there that you wouldn't see in the GUI.
Also rather than a reset, does Alt + SysRQ REISUB? That is a much safer way to reset unless it's truly "locked" up.  Quick article for REISUB
I did not know about Alt + SysRQ REISUB I will try that next time it freezes. I will also try launching from the terminal.
sudo apt update
sudo apt upgrade
sudo apt autoremove
sudo reboot
And try again
Running the update commands from the terminal did not help. As soon as I started downloading a game everything froze again.
I also tried using Alt + SysRQ REISUB but that did nothing to unfreeze it.
When I launch steam from the terminal I get this WARNING: Using default/fallback debugger launch for the fifth line down. But it opened and continued to download then it froze again.
Does the system also freezes randomly at other tasks?
