2 minutes ago, Egghead101 said:
My question is: is it normal to boot to bios when changing a PSU or did I mess something up?
A lot of systems will perform a first time configuration boot when you change something, not often is the power supply a factor but I am not surprised if some motherboards detect that.
Assuming your system is not continuously going to BIOS, you don't have a problem.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1365687-changing-psu-question/#findComment-14935541
This
If you can't get into the OS, make sure you have your OS drive plugged into the PSU (if it's a sata drive)
https://linustechtips.com/topic/1365687-changing-psu-question/#findComment-14935546
