PCIe power connector placements for PSU when using high powered GPU (3090 RTX)
By
taavi
in Power Supplies
in Power Supplies
Solved by Spotty,
It does not matter, all of the CPU/PCIe slots are the same on that PSU. You can use the ones you circled green or the ones you circled red. I'd use whatever gives you the neatest cable management, but it doesn't matter other than that.
Featured Topics
Bobzcpu ·
Posted in Power Supplies2 -
1
RZBAKA ·
Posted in New Builds and Planning4 -
1
Magnumenforce ·
Posted in Phones and Tablets2 -
1
Crash The Noise ·
Posted in Programs, Apps and Websites3 -
5
