Budget (including currency): 1000$
Country: USA
Games, programs or workloads that it will be used for: League of legends and Valorant
I need help picking out the best possible parts for a 850$ build that also includes a monitor.
https://linustechtips.com/topic/1365494-need-help-with-850-build/
PCPartPicker Part List: https://pcpartpicker.com/list/Wp9M9N
CPU: Intel Core i5-10400F 2.9 GHz 6-Core Processor  ($150.99 @ Adorama)
Motherboard: Asus PRIME B560-PLUS ATX LGA1200 Motherboard  ($119.99 @ B&H)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($77.98 @ Amazon)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive  ($99.99 @ Walmart)
Case: Phanteks Eclipse P300A Mesh ATX Mid Tower Case  ($64.98 @ Amazon)
Power Supply: MSI 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Monitor: MSI Optix G242 23.8" 1920x1080 144 Hz Monitor  ($189.99 @ Abt)
Total: $793.91
Generated by PCPartPicker 2021-08-16 02:12 EDT-0400
For monitor you can go with this one MSI G271 or this one Acer vg270 with that you still have like 300$ left for a GPU
https://pcpartpicker.com/list/R6X6Jf
Maybe something like this?
5700g as i dont think youll be able to sqeeze a decent gpu in that budget
3733 ram incase you dont overclock it
Cheaped out on everything else whilst keeping quality decent
Monitor is up to you as i dont have any knowledge on monitors as ill just buy a cheap old monitor and overclock it to 75hz
It is highly reccomended to overclock the ram and igpu, if you reach the max fclk your cpu can handle it might start erroring or crashing so id suggest reaching near max fclk your cpu can handle that doesnt cause any errors or crashing then lower your ram timings
And for igpu ocing theres alot of tutorials for that, though supposedly these igpus can reach 2400mhz
