Bare in mind, I haven't bought the psu and cables yet, but trying to figure everything out. If this is in the wrong spot, I'm sorry.
The PSU I was looking at is the EVGA SuperNova P6 1000w and I was looking at the configurator on CableMods. I looked under their custom cables and I am unsure if the psu is consider to be P6, which is on the drop down, or would be supernova p6, which isn't. I am unsure if I should get custom cables or custom extensions.
The Case I have is the Phanteks Enthoo Evlov x case
Fire Tail: CPU - Intel 7700k. MOBO - MSI M5 Gaming Z270
RAM - G.Skill RipJaws V 2x8GB (16GB). GPU - MSI 1070 Gaming X
____________________________________________________________________________
Editing Rig: CPU - AMD Ryzen 3900x with NZTX Krackenx240. MOBO - MSI ACE MEG Z570
RAM - G.Skill Trident Z 32GB (16GBx2) 3200hz. GPU - MSI Gaming Trio 2070 Super
https://linustechtips.com/topic/1365290-cablemods-psu-help/
I would recommend you just buy an extension kit from cable mod instead of buying it for the specific psu. There are some at micro center for about 30 usd
https://linustechtips.com/topic/1365290-cablemods-psu-help/#findComment-14932960
extensions are not recommended. longer cable = more resistance = lower voltage
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1365290-cablemods-psu-help/#findComment-14932971
Issue with Microcenter is... is about eight hours away from me, unless those extensions can be shipped. The thing is, I don't want a typical 'red and black' color theme.
https://linustechtips.com/topic/1365290-cablemods-psu-help/#findComment-14934089
The question stands tho, if I would get the EVGA SuperNova P6, would the choice on CableMod's website be 'P6?' As I am unsure if there was another P6 without the SuperNova tag.
https://linustechtips.com/topic/1365290-cablemods-psu-help/#findComment-14935868
