So, the 4000MHz kit is cheaper? Get the 4000MHz kit. The total latency isn't that much different, so it's just basically more bandwidth for cheaper.
It's not likely you'll be able to actually run it at 4000MHz, at least 1:1 with the FCLK, but you can roll it over into tighter timings.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
24 minutes ago, Jashanlol said:
I'm trying to choose between the two ram shown below but I don't know which one is actually better. My CPU is a Ryzen 9 5950X. The top ram costs 239$ and has timings of 16-19-19-39. The bottom ram has timings of 18-22-22-42.
Maybe look at 4400mhz ram if you actually want to tune your ram like the patriot viper steel rams
Otherwise go for 3600mhz cl16 ram like ballistix, cause tridentz is pretty overpriced
you need lot of practice and time to oc ram and i mean 30$ more.  if i  was droping  200+ on ram why bother to oc it i would practice on a cheap set first
Samsung B die https://pcpartpicker.com/product/7jH8TW/gskill-flare-x-32-gb-2-x-16-gb-ddr4-3200-memory-f4-3200c14d-32gfx  If you want to play with it and overclock (because it's the best). 3600 c16 will be decent if you don't care to overclock.
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
