Can you provide examples?  As in actual fps numbers in what games at what settings and resolutions?
It's like saying I bought a Corvette and it isn't fast.  Not much to work with.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1364535-i-need-help-with-my-pc/#findComment-14927998
1920 x 1080
in rainbow six siege i get 60-80
rust 40-80
https://linustechtips.com/topic/1364535-i-need-help-with-my-pc/#findComment-14928001
17 hours ago, Nectolyt said:
How many fps in which game and what settings ?
max setting
rust 40-80
17 hours ago, Bill_Skills said:
Are updated drivers installed?
yes
https://linustechtips.com/topic/1364535-i-need-help-with-my-pc/#findComment-14928003
4 minutes ago, Da bot Lobster said:
Update GRAPHICS driver. Not CPU or chipset drviers. If you don't have Nvidia's GeForce Experience, download it. It will get you the latest Nvidia drivers for your GPU. Just seach Nvidia GeForce Experience on google.
https://linustechtips.com/topic/1364535-i-need-help-with-my-pc/#findComment-14928028
i have it and i already updated it yesterday and i keep it up to date
https://linustechtips.com/topic/1364535-i-need-help-with-my-pc/#findComment-14928035
In that case I'd recommend uninstalling the driver with DDU and reinstalling it.
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
https://linustechtips.com/topic/1364535-i-need-help-with-my-pc/#findComment-14928129
2 hours ago, Da bot Lobster said:
So i have an 3060 ti
and the cpu is i5 10600k 4.10 ghz
and the ram is ddr4 2x16 gb dual channel 2666Mhz
power supply is 750
 im not getting much fbs idk whats  the problem
Out of curiosity do you have V-sync enabled? also what is your refresh rate of your display?
Project Casper - Glass Tubing Build
Ryzen 9 5905x     |    Gigabyte Aorus Extreme X570    |   Strix 3090
GSkill 64gb 4000mhz   |    EVGA 1600T psu     |      3x Samsung 980 Pro NVME 1tb Raid 0
  4 x Crucial MX500 2tb raid 0   |    Glass Hard Line Tubing  - EKWB Blocks
https://linustechtips.com/topic/1364535-i-need-help-with-my-pc/#findComment-14928243
21 hours ago, comander said:
Some things to test out temporarily
1. Do you get higher frames when the resolution/settings are lower? If so then it's likely GPU related.
2. Do you get higher framerates when you close everything but the game? If so then it's likely CPU related (possibly a RAM deficit).
3. Are there other titles that run at an expected level? If so what are the general performance attributes of them?
Ideally when you go about troubleshooting you want to generate as DISTINCT hypothesis as possible (performance-GPU, performance-CPU, configuration-error, etc.) and find ways to test each hypothesis. The more DIFFERENT tests you run, the better as you want your tests to push in different areas (so not the same thing over and over).
in rust setting dont really change the fbs even the res i play on 1920 by 1080
im thinking its either cpu or ram
Edited by Da bot Lobster
spelling mistake
https://linustechtips.com/topic/1364535-i-need-help-with-my-pc/#findComment-14930121
