Hi everyone I overclock my msi gtx 670 power edition using msi afterburner (Power Limit 114% Core Clock +100 Memery Clock +50) and I run some stress test and stability test everything is fine but whenever I try to play a game (GTA V) it just crash after like 5 minutes of gameplay and sometimes it just shuts down (not that often)
My PC Spec:
Mobo: gigabyte ga 790xt usb3
Cpu: amd phenom ii x4 965 Black Edition
Ram: Puskill DDR3 8GB x2
          Kingston DDR3 2GB x2 (IDK any of the frequency but HWINFO says it's all running at 726.7MHz)
Gpu: msi gtx 670 power edition
Storage: x1 ssd x2 hdd
PSU: Cooler Master GX750 - CM STORM EDITION
Cooler: AIGO DARKFLASH TRACER DT-240
https://linustechtips.com/topic/1364006-gpu-overclock-issue/
so couple of things. power limit you shouldnt touch, especially with an already older card. Its like giving a grandma extasy, might not take it to well… 😅
also +100, +50 seems sound, try that *without* touching the power limit (see above)
and also while you might see some improvements, it wont be much (3-5 fps *maybe*)
lastly can also try +25 core + 150 memory, something like that, +50 core might already be too much (if unlucky) gotta play around a bit with this to see whats stable.
-Scott Manley, 2021
https://linustechtips.com/topic/1364006-gpu-overclock-issue/#findComment-14924228
i got it to run at+50 and its very stable thanks man
https://linustechtips.com/topic/1364006-gpu-overclock-issue/#findComment-14924262
