I have 3080ti FE and temps on idle are 45-50C, with fans on and undervolted. I have airflow restricted case tho (NZXT H710 when I was buying it I was going to buy 3070 but shortage happened and I ended up with 80ti).
When gaming, temps are good (for a 350W tdp card), barely go up with less demanding games like CS GO (usually bellow 55C), GTA ( bellow 65C), and Cyberpunk (below 75C). But the idle temps are weird. Tho I've heard Moore's Law Is Dead talking that people are reporting 50C idle temps, when I asked about that on r/Nvidia some told me that it's completely normal, others that it's not (someone even said they have 35C @ idle).
So my questions:
1. Are idle temps like this normal for 80ti FE in poorly ventilated case.
2. Will changing case fan setup to positive pressure help (now I have 3x 140mm exhaust and 2x 140mm intake mounted on AIO)
3. I have it mounted verticaly, can this be an issue?
https://linustechtips.com/topic/1363532-rtx3080ti-fe-temps/
Those temps, both idle and load, seem fine for that card in that configuration.
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1363532-rtx3080ti-fe-temps/#findComment-14920967
Thanks, I was just really worried since I always had a low end system and now that I have this and some people told me smth is wrong I got really worried. Well, all I can do now is change fan configuration. NVIDIA putting GDDR6X in their cards was the biggest clown move I've seen in a while.
https://linustechtips.com/topic/1363532-rtx3080ti-fe-temps/#findComment-14920974
