Budget: 7000 - 9000 PLN max (just for the pc, no peripherals)
Hello, I would like to know if this is a good part list. https://pcpartpicker.com/list/yjHG9N  I’m going to build this pc in Poland within the next month, but most of the US prices are equal to 1/4 the PLN prices here. This PC is going to be used mainly for gaming and programming. Also, Im not sure if I should get a RTX 3060, 3060 Ti, 3070 or 3070 Ti, 3500 PLN ($900), 4000 PLN ($1040), 4800 PLN ($1250), 5000 PLN ($1300) respectively.
https://linustechtips.com/topic/1363183-pc-build-help/
You can quickly nick in a 3080 at MSRP for the CPU pairing, but i would expect itll bound to go down to the 800$ boundary by the time stock starts to bloom at the end of this year. With that in mind, you can go better:
PCPartPicker Part List
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor  ($569.99 @ B&H)
CPU Cooler: be quiet! Dark Rock 4 CPU Cooler  ($69.90 @ Amazon)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  ($124.99 @ Amazon)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($139.99 @ Newegg)
Storage: Team T-Force Cardea Zero Z330 1 TB M.2-2280 NVME Solid State Drive  ($92.99 @ Amazon)
Storage: Seagate 4 TB 3.5" 7200RPM Internal Hard Drive  ($69.98 @ Amazon)
Video Card: NVIDIA GeForce RTX 3080 10 GB Founders Edition Video Card  ($699.99 @ Best Buy)
Case: Phanteks Eclipse P360A ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply: Super Flower Golden Green HX 750 W 80+ Gold Certified ATX Power Supply  ($69.99 @ Newegg Sellers)
Total: $1907.81
Generated by PCPartPicker 2021-08-08 02:28 EDT-0400
3 minutes ago, ET_Explorer said:
See warning at bottom of PCPartPicker List.
Which you can easily ignore because by this stage of production every B550 boards have 5000 series support.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1363183-pc-build-help/#findComment-14918776
Total: $1907.81
Thank you. :D
https://linustechtips.com/topic/1363183-pc-build-help/#findComment-14918793
