This is my first time building a PC. I am building a new PC basically from scratch and am wondering about any thoughts on the build.
I will mainly be using it for gaming, coding, and Virtual machines.
The CPU, MOBO, RAM, and GPU have been bought or are being carried over from my old PC and I will probably be adding more fans.
My main concern is with the CPU cooler. Thanks
PCPartPicker Part List
CPU: Intel Core i9-10850K 3.6 GHz 10-Core Processor  (Purchased For €0.00)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  (€109.85 @ Komplett)
Motherboard: Asus PRIME B460-PLUS ATX LGA1200 Motherboard  (Purchased For €0.00)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-2666 CL16 Memory  (Purchased For €0.00)
Storage: Western Digital WD Blue 500 GB 2.5" 5400RPM Internal Hard Drive  (Purchased For €0.00)
Video Card: NVIDIA GeForce GTX 1060 6GB 6 GB Founders Edition Video Card
Case: Corsair 4000D ATX Mid Tower Case  (€106.98 @ Currys PC World)
Power Supply: SeaSonic FOCUS 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€118.95 @ Komplett)
Total: €335.78
Generated by PCPartPicker 2021-08-07 21:25 IST+0100
https://linustechtips.com/topic/1363088-first-build-help/
Total: €335.78
get a cheaper cooler, and a SSD. Otherwise it looks good
https://linustechtips.com/topic/1363088-first-build-help/#findComment-14918172
That cooler is among the best air coolers on the market. Primary consideration, not the best idea to transport your pc around with it attached. Cooling should not be a concern
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1363088-first-build-help/#findComment-14918181
I saw the i9-10900 cooling video and assumed that the cooling necessary would be similar. The other thing I was considering using would be an AIO. I think I could be hitting the cpu hard as I sometimes run multiple VMs at once and normally allocate at least a core to each and prefer leaving at least a couple of cores for my host.
Here's the link
https://linustechtips.com/topic/1363088-first-build-help/#findComment-14919360
I was more considering the size and whether I should switch to an AIO. I wouldn't be moving my PC around a lot so i don't think I would have to worry about the cooler moving around.
https://linustechtips.com/topic/1363088-first-build-help/#findComment-14919381
