Coputer vision proces on pc send wat to do to raspberry
Symbolls
So i have been playng arround with coputer vision a lot and i have found ways to make raspberry pi faster at traking but its not that fast still and i want to proces the coputer vison part on a coputers gpu over wofo but i cabt seame to find a way to do it or i am just googling wrong so if sombady has some tutorial on how to do it or somwat close (most importantly the data transmision and reciving part) pls let me now thx for reding.
I always just use ffmpeg to stream video to other PC's, then you can write a program that will do the processing that way.
It all depends on your setup though, ffmpeg might not be a great tool (but I have the code-base for my projects so I use it)
3735928559 - Beware of the dead beef
