Hi!
 my system:
rtx 3080
ryzen 9 3900xt
750w corsair
4x 8gb 2133mhz
my question is, how can i only get to an average of 140 fps in valorant deatchmatch on 1440p? i know that i need to upgrade my ram but when i see benchmarks they easily get 300+fps with a similar system
https://linustechtips.com/topic/1362772-low-fps/
RAM speed.
Its way too slow.
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1362772-low-fps/#findComment-14915923
10 minutes ago, NyxVenom said:
that really drops it in half? i tried changing my ingame settings around, high-low. they dont change a single fps
what internet do you have, is it good
Big nerd.
https://linustechtips.com/topic/1362772-low-fps/#findComment-14915969
250 down 50 up
Also when i swap to 1080p its still averaging 140fps
That would make the situation worse, not better, if you're already having a CPU bottleneck. The thing to consider with Ryzen is that it's not just about the memory speed itself. The FLCK of the CPU is tied to the memory clocks. With RAM that slow, you're actually affecting the speed at which the CCDs communicate, including for things like shared cache.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1362772-low-fps/#findComment-14915998
39 minutes ago, NyxVenom said:
Hi!
 my system:
rtx 3080
ryzen 9 3900xt
750w corsair
4x 8gb 2133mhz
Get faster ram. Ryzen CPUs like faster ram, and will perform a lot better with faster ram. I personally have 3200mhz, and it is fine. Make sure to get CL16 or less if you are getting 3200mhz ram
https://linustechtips.com/topic/1362772-low-fps/#findComment-14916015
ram upgrade it is, currently got a sale for a 2x8 3600 cl18 kit. that good?
https://linustechtips.com/topic/1362772-low-fps/#findComment-14916024
try 3600 cl16
Big nerd.
https://linustechtips.com/topic/1362772-low-fps/#findComment-14916031
