Any issues with DLSS on a 4k monitor that is running at 1440p?
Solved by Hairless Monkey Boy,
You should not use display or GPU upscaling with DLSS. DLSS reduces the render resolution and applies a superior upscaling algorithm. When using DLSS, you should use the display's native resolution, and use lower DLSS settings to further reduce the render resolution if you still need more FPS. This will achieve a better picture quality at the same frame rate vs using DLSS in addition to display or GPU upscaling.
But no, you should not have an issue with that, aside from an inferior picture quality.
