Budget?
The cases that can fit it, don't make it overheat AND are small are well really expensive. The founders card IS NOT MADE for itx as it's blow through style cooler is just about the worst thing for it as in most cases it blows air against a metal surface thus making the card run a lot hotter. It also comes with the issue that the backplate doesn't really get cooling and those poor vram chips are already cooking.
https://linustechtips.com/topic/1362657-itx-case/#findComment-14915037
3 minutes ago, Idle_Wild said:
£100-150.
I liked the look of the NZXT 210i but it only has two slots.  Don't suppose there's any way to make the 3090 fit in a 2 slot case?
Nope not happening.
Problem is here that the vram gets really hot especially without airflow (it's the reason 3090's died when playing new world).
The ncase m1 fits it just barely but again back side gets hot and card runs hotter due to cooler design not working well in that case. Also is a bit over budget at at least 180 pounds. Also psu doesn't fit
The nr200 would be the best possible one as it does the traditional layout but again psu won't fit.
So really best I can do is recommend you a fractal design meshify c mini as that is a regular case but smaller and will fit your parts.
https://linustechtips.com/topic/1362657-itx-case/#findComment-14915065
18 hours ago, Idle_Wild said:
Opted for the Thermaltake Level 20 VT instead, as it's a smaller cube shape case.
how about Meshify C mini?
https://www.fractal-design.com/products/cases/meshify/meshify-c-mini-dark-tempered-glass/black/
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
https://linustechtips.com/topic/1362657-itx-case/#findComment-14916905
