Will Be Quiet Dark Rock Pro 4 fit in NZXT S340 Elite ?
DopeSensei
If not, can you recommend other coolers that are similar.
Quote
Yeah, youll need to remove the side panel to make sure it fit. What CPU do you have?
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My name is Frill. Don't pretend not to see me. I was born from the two of you.
R5 5600x
3 minutes ago, DopeSensei said:
R5 5600x
Yeah, you wont need a lot to cool that thing. The stock cooler it comes with is enough, but if you want a sizable bump up, something like NH-U12S from Noctua is a good shot.
Well I want to overclock as well, now that you mention  NH-U12S is it better than the Dark Rock 4 (non pro).
the dr pro 4 exceeds the max height cpu cooler height for the s340 elite
Other big towers coolers you can look at are:
thernalright fc140
noctua nh d15s
thermalright fs140
thermalright pa120
Thermalright Le Grand Macho RT
scythe fuma 2
scythe ninja 5
ID-cooling se 207 xt
if you need single towers:
Noctua nh u12a
Arctic Freezer 34 duo
scythe mugen 5
ID-cooling se 234
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
4 hours ago, 8tg said:
Pics confirm, it fits
both the S340 and S340 elite
Wow it even looks like you have space left, what is your ram height ?
