Help! converting HDD Striped Dynamic to basic
By
Tiger
in Troubleshooting
in Troubleshooting
Solved by ross06187,
you could use windows to make a image of the raid 0. then delete the raid 0 and restore that partition to disk 1. (taking up some of the unallocated space)
it might work, sort-off. messing with raid/drive setups is generally a bad idea once there up and running.
Featured Topics
Darth Destiny ·
Posted in Graphics Cards0 -
Shadow1789 ·
Posted in CPUs, Motherboards, and Memory1 -
2
1
JewPacaBraZ ·
Posted in Troubleshooting1 -
johnny45 ·
Posted in Linux, macOS and Everything Not-Windows4 -
7
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
