Ryzen 5800x not boosting
Solved by DawNoFd3aTh,
1 hour ago, cacoe said:If you tried to enable an OC via either manual overclock or by enabling PBO (which is different to PB) - disable it and see how that goes, also set windows power plan to best performance.
I've given up on PBO and Auto OC and going back to 2012 where you're forced to manually OC, working fine at 4.35 1.181v. Maybe one day I'll try PBO again but otherwise thanks for the help!
