Hi
can you please help me out by identifying the name type for the ARGB header on my GPU - see attached image with circled connector. I thought it was a VDG connector but I’m wrong. It is four pins wide with the third pin missing. The pins are fine like VDG, so a 5V ARGB female connector doesn’t fit — it’s too chunky to fit past the backplate.
What I’m looking for is an extension cable so I can cable manage the lead running from the GPU RGB header to the ARGB header on my ASUS Strix motherboard. The cable supplied with my GPU is too short by miles.
Thanks for the help.
https://linustechtips.com/topic/1360947-need-help-identifying-connector-type/
And where do you plug in the GPU fan ?
Im just trying to understand , if you connect this header to the motherboard, what is going to be controlled by it?
Knowing this might also help finding the right connector…  not sure.
-Scott Manley, 2021
