GPU makes buzzing noise when under load
Go to solution Solved by RONOTHAN##,
It's probably coil whine. It's normal and does not damage the card. If it gets worse when playing higher FPS games (CS:GO for example), it's almost certainly coil whine. You can look up a video of what it sounds like if you want to make sure.
Hello, so recently I've upgraded from an R7 370 to a 2nd hand RX 580 and I've noticed that it makes a weird electrical buzzing noise when under load (when I play games). It's not really bothering me but I'm wondering if I should just ignore it or if I should be worried that there is something wrong with the GPU. Thank you in advance.
https://linustechtips.com/topic/1360701-gpu-makes-buzzing-noise-when-under-load/
It does get worse sometimes when playing games, so it's probably coil whine. Glad it's nothing serious. Thanks!
