Help with a new pc build
Go to solution Solved by Somerandomtechyboi,
https://ca.pcpartpicker.com/list/y8kfwz
Oof
Screw the case we dont need it in this budget, put the computer ontop of the mobo box, from personal experience works pretty well, just abit messy
If you are fine with going slightly overbudget get 16gb ram instead
Budget (including currency): CAD 500
Country: Canada
Games, programs or workloads that it will be used for: Call of duty Warzone
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I already have a 1060 but need rest of the parts to go with it. I would prefer a ryzen. Your suggestions will help a lot.
https://linustechtips.com/topic/1359445-help-with-a-new-pc-build/
Oof
