I have a liquid freezer ii 280 rev and my case is Corsair 5000d Airflow, the 280 rad doesn't fit at the top of my case, my motherboard is msi b550 mag tomahawk and cpu is ryzen 5 5600x at stock overclock/boost. Is it ok if i front mount my aio and should i do push or pull. please and thank you :)
https://linustechtips.com/topic/1359304-aio-mounting-issues/
Yep, a front mount should be fine 🙂 @EyeSii, just make sure that the pump assembly isn't the highest point of the loop and you should be fine. For less noise you could also try to make it so your tubes face DOWN instead of up with the front mount.
No need for push-pull.
https://linustechtips.com/topic/1359304-aio-mounting-issues/#findComment-14891008
is it ok if the fans are behind the radiator and set as pull/intake?
https://linustechtips.com/topic/1359304-aio-mounting-issues/#findComment-14891009
