I need help upgrading my pc
3 minutes ago, WickedThunder86 said:Thanks for the prompt reply,
For the GPU I don`t really need that much power. With only 256MB of VRAM allocated to the iGPU Games like Minecraft run at a acceptable framerates.
Also the PSU I have is a Antec Atom V450
The atom is a garbage psu so yeah limits used options. To cards that do pcie power only no extra cables.
Either way follow my advice on the ram so you get a little cpu performance boost from dual channel (doesnt do much on this intel generation but 5% boost is a good trade-off for losing 2gb of ram when your games won't use 10gb at all anyway if you go fro a 2x4gb kit.
For gpu keep it at the gt 1030 GDDR5 (VERY IMPORTANT IT IS THE GDDR5 VERSION!!!!!). Some other options listed from best to worst (looking at used market too) all without extra power needs keep that i mind some do exist with an extra 6pin connector those are a no go.
Gtx 1050 (4gb, 2gb is a waste)
Gtx 750ti
Gt 1030
Rx550
