Hello, so I've tested the switch with a multimeter and the switch works aka short is there and it makes also a normal click sound.
Anyone has an idea how I could fix that? It's 2 years old.
It always worked normal and it just stopped out of nowhere.
Should i test something specific with a multimeter?
Intel NUC 13 | i3 1315U2x 8GB 3600/CL16
AMD 7950x3d | Sapphire 7800XT Nitro | 2x 16GB Corsair Vengeance 5600Mhz CL36 1R | MSI B650-P Pro Wifi | Custom Loop
AUNE X8 Magic DAC + SS3602
AUNE X7s PRO Class-A | Sennheiser HD58X
Schiit Rekkr ELAC BS243.3
https://linustechtips.com/topic/1358713-g-pro-wireless-left-click-doesnt-work/
