Fan speeds problem
Solved by Bombastinator,
4 minutes ago, Lil.Pigeon94 said:So I went to the bios and I seen something dealing with fan control. When I click it what do I do from their. It shows my fans and their rpm's but I dont know how to control it.
This whole “reading the manual” part is important. There are a couple ways it could be done off hand. Usually it is some sort of graph which says run fans attached to [x] fan header when [y] temperature sensor reads [z] run the fan at [xx] speed. Most often that is expressed as a percentage of max speed. There should be several levels creating a curve of sorts. How those variables are set though varies a lot
