Hi guys , I hope no one's running into issues like me. So I have a
system with these specs :
~CPU : Ryzen 7 3700x
~GPU : Gtx 1070ti Strix
~Storage : 256gb Xpg nvme / 2tb HDD Seagate Barracuda.
~OS : win 10
~PSU : 1000w thermaltake
~Cooling: stock AMD RGB cooler(CPU).
~RAM: 2×8 (16gb) @ 3200mhz Corsair RGB.
~Mobo: Asus prime B550m
•Problem: i have stuttering/ FPS drops/low GPU usage/ GPU usage fluctuations and high latency In all games.
I never had these issues before , so before these issues my GPU would be fully utilized i.e 98% ~ 99% my CPU would change its clock speeds normally and its usage was around 30~40%.
•Attempted solutions:
*Tried reinstalling drivers/reverting back to older drivers.
*Tried changingpowerplan to maximum performance for GPU & CPU.
*Tried resetting PC in Windows settings.
*Tried clean caches and optimizing drives.
*Tried running all games in full screen, vsync disabled & ran them as administrator.
*updated bios through Asus armoury crate.
*Did furmark tests & monitored using HW monitor.
*GPU temps 70°~75° when underload & CPU temps 62°~70° Max for both .
*Disabled full screen optimizations for all games
*Set priority high , hardware acceleration on , high performance for all games in graphics settings in Windows.
*Nvme temps 60° Max and HDD 50° Max & Ram 55° Max.
*Disabled any kind of overlays and disabled gamemode.
*CPU clock is now fixed @4.5ghz on all cores because I oc it , before it were between 3.9 and 4ghz.
*Tried oc the GPU . Also noticed cck or core clock fluctuations during monitoring as it went from 1773 to 1835 or 1822 however memory clock was fine.
PLEASE HELP ME 😭
https://linustechtips.com/topic/1358178-low-gpu-usage/
Armoury crate Bios is usually pretty old. Just go to the ASUS website load newest BIOS and install it with AI Suite III.
What are the results of those benchmarks?
Have you tried DDU'ing your GPU drivers and fresh installing them after?
Desktop: i9-10850K [Noctua NH-D15 Chromax.Black] | Asus ROG Strix Z490-E | G.Skill Trident Z 2x16GB 3600Mhz 16-16-16-36 | Asus ROG Strix RTX 3080Ti OC | SeaSonic PRIME Ultra Gold 1000W | Samsung 970 Evo Plus 1TB | Samsung 860 Evo 2TB | CoolerMaster MasterCase H500 ARGB | Win 10
Display: Samsung Odyssey G7A (28" 4K 144Hz)
Laptop: Lenovo ThinkBook 16p Gen 4 | i7-13700H | 2x8GB 5200Mhz | RTX 4060 | Linux Mint 21.2 Cinnamon
https://linustechtips.com/topic/1358178-low-gpu-usage/#findComment-14883733
So during furmark and msi combustor my GPU is fully utilized until I fully crank up my settings in those benchmarks , I also noticed core clock speeds fluctuations during the bech and no I did not use ddu to uninstall my driver's I will try though. I am also gonna try to download the bios from Asus website.
Edited by Fatboi69
https://linustechtips.com/topic/1358178-low-gpu-usage/#findComment-14883805
