5 minutes ago, P0P said:
Is the stock r7 3700x stock cooler enough for gaming. I will not be overclocking
Yes. It’ll be fine.
https://linustechtips.com/topic/1357933-stock-cooler-enough/#findComment-14882056
Well, if you are not overclocking, then it should be fine. The stock cooler is going to be a little warm (running at about 80C at full load with just a little bit faster than your base clock).
I have Ryzen 3600, and the included cooler reach 80C with about 3.9GHz boost on all core. I changed to Hyper 212 LED Turbo, and my CPU is at around 70C running at 4.075GHz all cores most of the time. I just set every overclock-able settings to auto.
So, included cooler is sufficient. If you like, you can get a proper cooling tower for more performance.
I have ASD (Autism Spectrum Disorder). More info: https://en.wikipedia.org/wiki/Autism_spectrum
I apologies if my comments or post offends you in any way, or if my rage got a little too far. I'll try my best to make my post as non-offensive as much as possible.
https://linustechtips.com/topic/1357933-stock-cooler-enough/#findComment-14883898
