I've formatted my drives recently because I wanted to install a fresh version of windows onto my old pc. I've used the Windows 10 media creation tool to create a bootable usb. I'm sure the usb stick works because I've used it to install windows on a different pc. I've even tried formatting the usb multiple times as FAT32 and reinstalling the creation tool. The PC posts just fine and I can get into bios, however when I try and boot into the usb, this screen appears (photo I've provided) then turns black, but my pc stays on. I'm not seeing any debug leds stay lit when this happens so I am assuming all my components are fine. I've performed multiple cmos resets and still have gotten no where. Any help or advice are greatly appreciated!
Here are my computer specs:
CPU: RYZEN 5 1600x
RAM: 32GB 3200MHZ G.SKILL
GPU: ZOTAC GTX 1060 6GB
MOBO: MSI B350 TOMAHAWK
https://linustechtips.com/topic/1357860-problem-when-fresh-installing-windows/
2nd, trying the onboard graphics.  It looks like it is trying to run a resolution or refresh rate your monitor doesn't support.  Any Overclocking going on in BIOS or custom firmwares on the GPU?
Main Computer: CPU - Ryzen 5 5900x Cooler - NZXT Kraken x53  RAM - 32GB Corsairsrair Vengeance Pro GPU - Zotac RTX 3070 Case - Lian Li LanCool II RGB (White) Storage - 1TB Inland Premium M.2 SSD and 2x WD 2TB Black.
Backup Computer: CPU - Ryzen 7 3700x Cooler - CoolerMaster ML240 V2 RAM - 32GB G.Skill RipJaws GPU - Gigabyte GTX 1070 FE Case - Cougar QBX Storage - 500GB WD Black M.2 SSD
