UPS suggestions
Go to solution Solved by Chris Pratt,
I've been happy with mine. Not exactly cheap, but you can only go so cheap with a UPS. It's very much a you get what you pay for situation.
https://pcpartpicker.com/product/qvVBD3/cyberpower-cp1500pfclcd-ups-cp1500pfclcd
i want a cheap ups that can handle a pc that consumes id say around 600w and 2 monitors.
specs:
rtx 3080 msi gaming x trio
r7 5800x
32gb ram 3200mhz corsair vengeance rgb pro
b550 tomahawk
2x HDD 1x 1tb WD caviar green(very old) and 1x 2tb seagate barracuda
2x ssd 1x nvme 250gb 970 evo plus samsung and 1x sata m.2 450gb kingston
GX850 PSU from seasonic 80+ gold
g7 odyssey 1440p 240hz monitor
MSI optix mag 241c 144hz 1080p monitor
https://linustechtips.com/topic/1356935-ups-suggestions/
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1356935-ups-suggestions/#findComment-14875106
Same one I have, I second this.
I wouldn't go cheaper, you MIGHT be able to get away with the model one level down from this, but this one is usually only a few bucks more, and having headroom is good.
(looks like amazon is out of these right now, it's $199 at bestbuy)
System Specs: AMD 5950x PBO-AutoNoctua DH-15 Black | Gigabyte x570 MasterEVGA 3080FTW3 Ultra | (2x16gb) G.Skill Royal 3600mhz CL18 | Corsair 5000D Airflow (Black) Samsung 980 Pro 2TB & Firecuda 520 1TB & Crucial MX500 2tb850W Corsair RMX | 2 Noctua A14 CPU, 6 Noctua A12x25 Intake, 3x Noctua F12 Top Exhaust, 1x Noctua A12x25 Back Exhaust
Monitors: (Main) LG Ultragear 34" 2k Ultrawide 144hz IPS '34GP83A-B' (Side) Acer Predator 27" 2k 144hz TN 'Abmiprz'
Peripherals: Corsair K100 OPX | Logitech G502 Lightspeed | Corsair Virtuoso SE | Audioengine A2+
https://linustechtips.com/topic/1356935-ups-suggestions/#findComment-14876590
  • 2 weeks later...
sorry to impose on another persons thread, but would you have a estimate on how long the battery would last for me? I would be only plugging one monitor instead of all of them but i have a 39" 3840x1600 monitor, 9900k with 32gb of ram and am using a 970 with a 1200w PSU.
CPU: i9 19300k////GPU: RTX 4090////RAM: 64gb DDR5 5600mhz ////MOBO: Aorus z790 Elite////MONITORS: 3 LG 38" 3840x1600 WIDESCREEN MONITORS
https://linustechtips.com/topic/1356935-ups-suggestions/#findComment-14902783
Why in the world do you have a 1200W PSU for a 9900K and a 970? That doesn't actually matter, though. I can get 30 minutes or so of actual usage (light... no gaming or anything crazy like that) or about 90 min idle.
https://linustechtips.com/topic/1356935-ups-suggestions/#findComment-14902809
more than long enough to finish what your doing and shut down your pc safely.
1200w is very overkill for your pc, i bet your not even exceeding 600 watts in actual use.
https://linustechtips.com/topic/1356935-ups-suggestions/#findComment-14902862
1200w is very overkill for your pc, i bet yout not even exceeding 600 watts in actual use.
the thing is like 8 years old. I had it when i was stupid enough to get 4 980's.
I have a new 850 in my closest when it dies
https://linustechtips.com/topic/1356935-ups-suggestions/#findComment-14902901
  • 4 months later...
if anyone cares. Using the pc and 1 monitor and a rasberry pi connected to one but with 900w i get like 25 minutes. running a game gave me like 20. Also it says i was not even using 200 watts playing a game.
And it uses a ethernet data cable USB which i didn't know they even had
https://linustechtips.com/topic/1356935-ups-suggestions/#findComment-15177024
