11 minutes ago, maxan3 said:
Hi,
I can't seem to get over 120 FPS in CS:GO, and i have a 3070 gtx graphics card. Can someone tell me how to fix this?
Thanks in advance :D!
Is your RAM duel channel? (2 sticks) also do you have XMP enabled in your BIOS?
Other than those, Windows updates, or V-sync, or a frame cap.. NVIDIA control panel has a setting in there some where for frame caps and changing the refresh rate of your monitor.
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    BenQ MOBIUZ EX2710Q 27"
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
https://linustechtips.com/topic/1356659-low-fps-in-csgo/#findComment-14872908
