Hello, when I launch a game (Such as Grand Theft Auto IV: The Complete Edition, Team Fortress 2, Half-Life 2, etc.), instead of detecting the Overclocked Frequency (I have an RX 580 8GB @ 1445 MHz for Core Clock and 2250 MHz for Memory Clock), it always "resets" the Overclocked Frequency to the Stock Frequency (1366 MHz for Core Clock and 2000 MHz for Memory Clock). How do I fix this?
SPECS:
Asus B450M-A II| Ryzen 5 3600 (6 Cores, 12 Threads) @ 3.6 GHz | XFX GTS Radeon RX 580 8GB w/ 2304 Cores, 144 TMUs, and 32 ROPs Overclocked (OC) to 1445 MHz for Core Clock and 2250 MHz for Memory Clock| XPG Adata 1x8GB DDR4 @ 3000 MHz/3 GHz|WD Green 240 GB (2018 Edition) SSD| Seagate ST2000DM005-2CW102 @ 1.81 TB or 2TB Storage| KB-161-306 Chroma Keyboard 100% CyberPowerPC| Logitech G502 HERO Wired @ 100-25,600 DPI @ 40G and 400 IPS with 1000 Hz (1ms) Polling Rate| AOC G Line 2nd Gen C27G2 1500R (Full High Definition) Adaptive Sync @ 165 Hz 1000Hz Response time (1ms) HDMI. AUX Bose 2 Series III Multimedia Speaker 2 Channel| Arris TM1602 Max TR speed @ 960 MBPS with DOCSIS 3.0, PacketCable 1.5, 1.0, and 2.0. Line Coding Format @ 8 QAM, 16 QAM, 32 QAM, 64 QAM, and QPSK.| CyberPowerPC GMA5200BST Pre-Built.
https://linustechtips.com/topic/1356234-problem-with-msi-afterburner/
You need to get into the Radeon Software, click on Performance (on top nav bar), select "Tuning" (under top nav bar), and use the "Manual" Profile.
Ryzen 5 3600 | Gigabyte B550 Aorus Elite V2 | XFX 6700XT 319 Black | 16GB 3200Mhz CL16 | 600W BeQuiet  Pure Power 11
I'm going to try that right now. If it works, then i'll mark your post as a correct answer.
SPECS:
Nope, the solution didn't work, I tried it, but still resets it to the stock frequency.
SPECS:
