I recently bought a 3d printer and there was this USB drive that had some .stl files and the slicer program for the printer and some other stuff on it for the printer. Everything was going fine with the set up when someone (me!) stupidly hit the update firmware button on the printer while the memory stick was plugged into it. I cancelled the update and plugged the memory stick back into my laptop. It says I have to format the drive again and in properties the memory stick reads 0 bytes. Have I lost all the data permantly? If it's not lost would I have to go to a data recovery company or would one of the many solutions work that come up when you google this stuff?
Sorry if this is not suitable for here in advance. I know I'm a plank and I'm kicking myself. Any help would be much appreciated even if it's the bad news that it's lost permanently.
https://linustechtips.com/topic/1356088-usb-flash-drive-help/
Here's an article I found from a quick google search. https://www.cleverfiles.com/howto/recover-usb-drive-windows.html
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1356088-usb-flash-drive-help/#findComment-14868735
Have you not checked the printer manufacturer's site to see if you can download the software?
Other than that you could try any number of recovery apps, some paid, some free....but chances of recovering from a USB flash drive that I am assuming was interrupted in the middle of a format operation are low.
https://linustechtips.com/topic/1356088-usb-flash-drive-help/#findComment-14868737
I have checked the printer manufacturer's site and the software is paid and quite expensive and I have called them and ask would they be able to send a copy on and they're being quite difficult to work with. Any recommondentation on which of these recovery apps is best? I had a bad experience a while ago with downloading software so I'm just a bit weary about which one I should download. One that seems to keep coming up for me is disk drill and someone I know said to keep away from that one. Is it any good in your experience? Thank you so much.
https://linustechtips.com/topic/1356088-usb-flash-drive-help/#findComment-14868899
59 minutes ago, Bh167 said:
I tried a few of these and no luck haven't tried the disk drill, do you know if it's safe to use?
Try Testdisk from here, https://www.cgsecurity.org/wiki/TestDisk_Download , read the info before use to make sure it will do what you expect.
https://linustechtips.com/topic/1356088-usb-flash-drive-help/#findComment-14869052
Thank you so much, testdisk worked perfect however I think you were correct, everything that came back was corrupted in some form except for 2 pdfs that survived.
https://linustechtips.com/topic/1356088-usb-flash-drive-help/#findComment-14869505
3 hours ago, LWM723 said:
If you send the manufacturer a wecopy of your bill of sale I'm sure they would provide a replacement.
I contacted that manufacturer again today over the phone as they are not local and we got a better rep and they said they will send the slicer program over again, hopefully. Thanks for everybodys help.
https://linustechtips.com/topic/1356088-usb-flash-drive-help/#findComment-14869515
Yeah, flash memory is almost impossible to recover data from due to the way data is stored on it and stuff like wear leveling.
Glad you were able to get a solution from the manufacturer! Make sure you backup the new drive. Flash drives don’t last forever either!
MacBook Pro 16 i9-9980HK - Radeon Pro 5500m 8GB - 32GB DDR4 - 2TB NVME
iPhone 12 Mini / Sony WH-1000XM4 / Bose Companion 20
https://linustechtips.com/topic/1356088-usb-flash-drive-help/#findComment-14869605
Great result, if they keep their word. It is unusual for device manufacturers to not allow downloads of software bundled with a purchase, most times you just need to register the product via it's serial number to gain access to the downloads section.
https://linustechtips.com/topic/1356088-usb-flash-drive-help/#findComment-14869606
