Hello everyone, I'm here to get some advise on my first build, I'm trying to build a gaming and workstation pc and I'm super excited to be upgrading from my laptop.
Budget (including currency): 2500SGD
Country: Singapore
Games, programs or workloads that it will be used for: I'll be playing COD and battlefield as well as running design softwares such as Adobe, rhino 6, sketchup, Vray and Keyshort. On average I'm running multiple software together like rhino 6 having it render a product in the background while I work on Adobe illustrator with photoshop.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I'm upgrading from a predator helios acer laptop. Planning to build it in December, as I'm currently schooling and slowly saving up money for the built. I'm just aiming for a 1440p, I'm not sure about refresh rate.
The specs for the build:
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor
CPU Cooler: Noctua NH-D15 CHROMAX.BLACK 82.52 CFM CPU Cooler
Motherboard: Gigabyte B550 AORUS PRO AC ATX AM4 Motherboard
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-4000 CL19 Memory x2
Storage: Seagate IronWolf Pro 4 TB 3.5" 7200RPM Internal Hard Drive
Western Digital Blue SN550 2 TB M.2-2280 NVME Solid State Drive
Case: Liang Li Lancool II Mesh Performance
Video Card: NVIDIA GeForce RTX 3070 8 GB Founders Edition Video Card
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Operating system: Microsoft Windows 10 Pro Full 32/64-bit
Total Cost: 3857
https://linustechtips.com/topic/1356050-first-pc-build/
