4 minutes ago, Bentbadly said:
What is the difference between  570 motherboard and  450 board. I want to upgrade to take advantage of PCI 4, and future upgrades.
Thanks in advance.
what? X570 and B450?
geometry is hard
b550 > x570
X570, B550 and B450. The letter here is part of the name, please dont omit them.
B450 has no PCIe 4, B550 only has PCIe 4 on the top PCIe x16 slot and M.2 slot (some boards offer two PCIE 4.0 x8 or PCIe 4.0 x8 + 3 M.2 w/ PCIe 4), X570 has PCIe 4 everywhere.
Desktop benching:
Thanks in advance.
Put it simply x570 is top tier chipset (not the motherboard since there's relatively shit motherboard with that chipset) you got the whole pcie gen4 connectivity with much more i/o than b550
B550 is, well, somewhat "stripdown" version of x570 you got less io plus you only got pcie gen4 doodads on the very top/ first pcie x16 and m.2 slot
B450 is last gen, more or less in the "same tier" as b550
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
Its not worth investing into a AMD system at this time for any "future upgrades" since they already announced a new socket type for the next gen.
Slayerking92
<Type something witty here>
<Link to some pcpartpicker fantasy build and claim as my own>
17 minutes ago, Bentbadly said:
ASRock B550 Taichi AMD AM4 3rd Gen and Future Ryzen 289$ cad
MSI MAG X570 TOMAHAWK WIFI, DDR4 Boost 339$ cad
AMD Ryzen 7 3700X 8-Core/16-Thread or
Buildzoid from AHC recommends the b550 steel legend/B550 Aorus Pro on the higher end, or B550 A-Pro on the mid range.
https://youtu.be/ihg6XQiqW7A
There's no need to overpay and get an x570 motherboard unless you need the extra features it offers.
CMIIW
Feel free to @ me if you have any questions!
Please press the button if you think my advice was helpful! Thanks!
"Min-Maxing may not always be the best thing to do, but I will always try." - Me, 2021
PC specs:
-i5 2500k
-TP67B+
-Zotac gtx 970 (the wimpy version)
-256gb V-gen nvme ssd (@ me if you want to know how I gave my P67 board NVME support)
-1tb wd blue hdd
-Corsair CX550
-MSI Mag forge 100r
Alder lake is also going to get a new platform so you are kind of screwed either way
¯\_ (ツ)_/¯
5 minutes ago, curiousmind34 said:
Alder lake is also likely going to get a new platform so you are kind of screwed either way
¯\_ (ツ)_/¯
Not just "likely", it will be on a new socket.
Desktop benching:
1 hour ago, Bentbadly said:
so will this only effect the motherboard and CPU. or will effect all computers parts.
The switch from DDR4 to DDR5 may be a factor with the socket change.
Slayerking92
