15 minutes ago, 8arib said:
no it’s not new  i had the same gpu since october but changed everything else here’s my specs:
nzxt h510 elite case
rm750 psu
x470 gaming plus max
gtx 1660s
r7 3700x
nzxt m22 cooler
corsair 16gb 3600mhz vengeance pro
Rip
if you hadnt spent the money on rgb pro which is horrible value even for rgb ram and a borderline useless aio you could have prob gotten a 5800x xD
Oh and the case has horrible airfow fyi
Try reseating your cpu, graphics card, and ram
Check all your connections make sure nothing is loose
And just in case if this is of any help
Heres some tests to run to make sure it isnt your hardware thats causing this (issue)
Prime 95 for 30 mins (cpu)
Furmark for 30 mins (gpu)
memtest 5 loops (ram)
If any of them crash or error (memtest) then report it here
on top of that its likely  op has "cam" installed which in turn is likely to be responsible for the shutdowns. That or overheating is my guess.
-Scott Manley, 2021
