if anyone here has experience with the GT501 case, i was curious if the RGB fans will only be compatible via an ASUS mobo (IE aura sync) or if you could say hook the fans up to a ASROCK (polychrome) or other mobo. i know asus tends to play nice with asus but was unsure if i should get an asus motherboard for the best compatability.
https://linustechtips.com/topic/1355459-gt-501-case-question/
51 minutes ago, AlfaProto said:
Does your ASROCK motherboard support ASUS' Aura Sync?
i do not have an asrock board. i was simply asking if the case fans are only compatible with Aura sync or not. i am debating between a Taichi and a ROG board but dont know the case compatability
https://linustechtips.com/topic/1355459-gt-501-case-question/#findComment-14864227
https://www.asus.com/us/Motherboards-Components/Gaming-Cases/TUF-Gaming/TUF-Gaming-GT501/
Shows that the RGB is of Aura Sync, so any motherboard, fan, RAM, etc that has Aura Sync support will work.
https://linustechtips.com/topic/1355459-gt-501-case-question/#findComment-14864258
ok thanks man, u just got urself a new follower. thanks for the help
https://linustechtips.com/topic/1355459-gt-501-case-question/#findComment-14864278
