Hi,
I have a problem with my GPU.
It runs too hot like 80 degrees C when in full load. It is Gigabyte RTX 2060 OC version (double fan).
My case is Fractal design define mini C and I have 5 fans in it. 2x front intake 140mm, 2x exhaust top fans 140mm and 1x rear exhaust fan 1200mm. Those fans are from Noctua so they are good. Even if my fan curve is set to 100% it gets to the 80s and more...
GPU is brand new!
Is there any way how to fix those temps ? Maybe some software tweaking ?
Thanks for any help.
https://linustechtips.com/topic/1355050-gpu-running-too-hot/
Try turning those roof fans off as now they might just take all that fresh air coming in from front and exhaust it before it reaches the gpu.
Some gpu:s just have bad coolers. Fan count wont mean much if its a crappy aluminium flower style cooler with some heatpipes attached to it for looks.
https://linustechtips.com/topic/1355050-gpu-running-too-hot/#findComment-14861459
Under full load that was still pretty normal..
If you want to lower it, try to increase the gpu fan speed instead of case fan one...
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
https://linustechtips.com/topic/1355050-gpu-running-too-hot/#findComment-14861461
9 minutes ago, Sweezek said:
I meant my GPU fan curve is set to 100%, also my case fans run at 100%.
And those temps are still pretty ok,
If noise is kinda problem to you then you can tune the fan little by little so it wasn't making it hotter and reducing the noise
https://linustechtips.com/topic/1355050-gpu-running-too-hot/#findComment-14861474
