Budget (including currency): $2500
Country: USA
Games, programs or workloads that it will be used for:  Tarkov, Warzone, Rainbow Six Siege, future FPS titles, work from home mainly out of Chrome based programs.
Other details Will be playing at 1440p currently but may upgrade to 4K in the near future.
https://www.ibuypower.com/Store/AMD-Ryzen-Streaming-PC-Daily-Deal/W/1538021
https://linustechtips.com/topic/1354983-thoughts-on-a-first-build-needed/
RAM : Dont take 3600Mhz, it's useless. The biggest bump in performance is from 2666Mhz to 3200Mhz. Higher is a waste of money and you will only gain 3fps in games... I whould take 2x8Gb 3200Mhz cl14/cl16.
The rest seems fine to me even tho you could get better storage. You want to install big games and you only have 1Tb. You should get a 1Tb HDD for 50$.
One other thing I would change is the 360mm AIO. The ibuypower ones are pretty decent and the 360mm one is $72 less. To be honest you could easily get away bumping it down to a 240mm aio, but the 360mm ibuypower aio is not that much more expensive.image.png.5bcf6fee7afd07d43c27b9c76adb6aa5.png
Depends on what you want. Look closely into the specs and identify if you want -lower noise levels -RGB -the radiator thickness
I think the iBuypower one is only cheaper because is has no RGB on the fans.
Tbh if op isnt gonna oc, a 240mm would be completely fine, 360mm would just be wasting money
No plans to OC off the bat but I would like that option down the line and the price difference is only about $20 between the two. Rather have it and not need it than need it and not have it.
I guess youll atleast get lower temps so not completely useless ¯\_ (ツ) _/¯
True. If it was a $50+ price difference I might rethink but the difference is fairly miniscule when it comes to the total cost of the build.
