Budget (including currency): ~1700 AUD
Country: Australia
Games, programs or workloads that it will be used for: Will be used for mostly older games, but would like the capability to play newer releases on low settings. Will also be used for light programming and word processing.
Other details https://au.pcpartpicker.com/list/tdBDLP
Just wanted to know if all this looks good.
Thanks for the help.
https://linustechtips.com/topic/1354872-first-pc-build/
Country: Australia
Looks good
Though dont waste money on windows 10, an oem key online is like 20$ from sites like scdkey and if you are fine with a random key 3$ on ebay
https://linustechtips.com/topic/1354872-first-pc-build/#findComment-14860389
