2 hours ago, ShariQuinn said:
I was wondering if these parts would all work together I do know that this is a pretty unbalanced pc but I just need to know if it works.
https://ca.pcpartpicker.com/list/MWMfbh
Ram is garbage, why single channel bruh single channel absolutely cripples cpu performance
Silicon power turbine 16gb kit is like 71$
500gb nvme ssd like sn550 is 22$ more, usually below 500gb ssds have garbage value
That case front panel looks like airflow hell, i think theres a mesh version callex matrexx 55 or not just go with a p300a
5850 is quite an old card but you should be able to play some games, maybe bios mod it to 5870
Psu isnt the best but it atleast shouldnt catch fire
6.5/10
single channel ram, rubbish airflow, quite a few optimizations to improve performance and value
Though in its current state it will work but itll run like crap cause single channel ram and rubbish airflow
I’ve seen this case before and with fans in the front which I already have has actually pretty good airflow especially for the kind of hardware I am putting in there, the graphics card is pretty crap but with the GPU shortage and everything it’s all I could find but will be fine for my purposes, finally the ram yes it cripples performance to have single channel but I am on a super tight budget and I plan to throw in another stick like next week because I only have around 450 Canadian dollars to spend so because I am in Canada a lot of those prices would actually translate to much more thank you for the information though I will definitely try to bios mod it.
