First budget Gaming Rig (Help)
Go to solution Solved by RedDeath_,
8 minutes ago, KingSavage132 said:
The GPU I'm thinking of getting is GTX 1060 4gb.
*I think you mean 3gb
The build you have is a well all-around budget pc. However, you won't be able to play big games like GTA at 60fps High/Ultra. As emosun said, to do that consistently, you'll need at least a GTX 1660 Ti.
Budget (including currency): 700 USD($)
Country: United States of America
Games, programs or workloads that it will be used for: Grand Theft Auto V, Fortnight, Call Of Duty: Warzone, Minecraft, Photoshop, Discord, Sony Vegas Pro 16
Other details: The parts I already have is a GT 1030 (Willing to upgrade in the near future) Upgrading from a Upgrading Dell OptiPlex 3010 MT, Resolution I want to play is 1920x1080 at 75hrz fps for the games I would like the FPS to be 60 or more.
Here is the PC Part Picker Link: https://pcpartpicker.com/list/LNmyCz
I'm new to this, if anyone can tweet the parts or can tell me what's not suppose to be in there, thank you.
https://linustechtips.com/topic/1354510-first-budget-gaming-rig-help/
2 minutes ago, KingSavage132 said:
Thank you, im the future im thinking of getting is GTX 1060.
well i use the 1060 6gb and a few of those might run at 1080 60. But the 1060 is over 5 years old now and it probably won;t be supported or have that kind of speed for much longer. You should be looking at something newer than a 1060 when that time comes
If you think that's the choice ill have to wait a few more months. Not complaining just you know, trying to get the best gaming experience.
If you can afford an Rtx 3050, 3050 Ti or 3060, you should wait to get one at mrsp. It would do the job pretty well at a "low" cost.
Yeah, i heard the RTXs are pretty high at this moment, with all this information I probably should hold of with the parts right now and still to my low end rig right now. It does well.
