12 hours ago, shaneh890 said:
Im filming a funny video and would like the mortal combat "round one fight" sound effect and overlay of the words pop up on screen. Im not worried about copyright and whatnot cause its for personal use. Anyone know how to get that or easily make it?
For text, Adobe do not copyright people that use features in their software. You will be fine for that unless you use a font which you do not have the rights in use (like something you downloaded ages ago and forgot).
If the audio talked is from the video game, that may be an issue however likely will constitute as fair use depending on what you do with the video.
https://linustechtips.com/topic/1354442-premiere-pro-help/#findComment-14858293
